Is it possible to upgrade the MacBook Pro 13" (Early 2015) as a whole
I love my Retina MacBook Pro (Early 2015), it is probably the last MacBook with best keyboard and all the ports. I want to use it as long as I can. However, it is kind of slowing down on performance. I would like to know if upgrading the logic board (with 16gb ram instead of current 8gb), a new battery and a possible UPGRADE of better quality retina display will help, or is it worth that? I plan to install a new logic board, along with better thermal paste, new fan, Intel 760p SSD (for power consumption reasons), a better display from newer MacBook Pro if compatible and battery. What are your thoughts on it?
Update: It seems that the capacity of battery has gone down to 95.7% (still good enough as per the numbers) however, the percentages go down significantly and even in Sleep mode, I’m losing so much battery power. I have reset the PRAM and SMC just now though.
Это хороший вопрос?
1 Комментарий
Upgrading of MacBook Pro 13 is good. You can get Macbook Air Logic Board I3 Online in Usa.
https://appleparts.io/macbook-air/
из SKLADCO LLC
