Broken cable clamp on Orange flat cable
After replacing the battery on my 10.1” galaxy tab 3, the little bar clamp on the orange cable broke and the cable does not clamp down in the slot. Swiping the screen is now erratic and often not even happening. I guess this is the problem as I have changed the battery before with no ill effects. Is it repairable?
Holding the cable in place with tape does not help.
Это хороший вопрос?
5 Комментариев
Can you add a photo
из daniel
Thanks for your quick response Daniel, can't seem to paste the copied photo. if its any help the little bar was a brown colour and snapped in the middle and both parts disappeared.
If you know how to post the picture I have it.
из Dennis
You can edit the post and add a photo. Click on options and edit
из daniel
Sorry Daniel this isn't working for me. I'll report back after the white tak attempt
из Dennis
https://www.dropbox.com/sh/axs768psmbm9m...
I have dropped the photo into here, hope it helps because the white tak solution has not performed
из Dennis
