Help, Repair FPC contact pads a1278
I bought a cheap hot air solder iron and applied to much force with tweezers and ended up ripping 5 of the contact pads off should of just stuck to the regular solder… Is this repairable? It looks like I would be able to run wires possibly? Any info on where to run wires would be greatly appreciated!
I located this, not sure what part of the logic board this is? Do I run wires to these locations? Is this the chip right below the connector?
-Daniel
Это хороший вопрос?
2 Комментариев
If anyone knows the location of where I can run wires to the new chip it would be greatly appreciated!
из linksfury22
Before you worry about the chips lets see if you can remount the ribbon connector. Clean the pads off using a soldering iron and solder wick. Also see if you can re-tin the pads, if not get some copper foil tape to repair them. Once you've got them rebuilt clean off the connector and remount it.
If you did it right you shouldn't need any jumpers.
из Dan
