Обновленная версия iPhone 3G с более высокой скоростью обработки. Ремонт этого устройства схож с iPhone 3G, и требует простых отверток и инструментов для вскрытия. Модель A1303; 16 или 32 ГБ памяти; с Черной или Белой задней пластиковой крышкой.
1963 Questions Показать все
iPhone Battery Still Not Lasting With New ifixit Battery Kit
My iphone hasn't been holding a good charge. Before installing a new battery I was getting about 12 hours of standby time. I purchased and installed the ifix it battery kit, and haven't come up with different results in the battery life department. Is there a way to calibrate iphone batteries? Is there something else I can do to make my battery go longer? I've done all of the obvious things that I can such as turning down the brightness on the screen, setting auto lock to one or two minutes, turning off bluetooth, with the same results. Any ideas?
Thanks for the help
Это хороший вопрос?
по рейтингу 0
Комментарии:
interestingly someone else has this problem with an ifixit battery..contact them and see whether this is a problem with the batch..might also be a software problem with the latest update??
от
Do you have a Jailbroken device?
Which firmware?
do you use iPad BB - 06.15?
от
This unit is not jailbroken. I have the latest firmware available.
от
If it is not a JB device, I might offer you to restore to the latest FW - 4.3.3.
If it won't work, contact iFixit.
от
Добавить комментарий
Комплект инструментов для замены батареи Macbook
Доступно с $69.99
Buy Now
Доступно с $69.99
Buy Now
1 Ответ
Наиболее полезный ответ
I would swap in the old battery first and see if it shows a similar behavior. If it acted normal (like before the battery change) then I blame the new battery. Ifixit had a bad batch that were sent out with a lot of frustrated customers. Just contact them and they will send out a new one.
Был ли этот ответ полезен?
по рейтингу 1
Комментарии:
Good idea. But a pain to remove those adhesive strips I took such care with!
от
Добавьте свой ответ
Nate будет вечно благодарен.
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 1,195
