Fans full throttle after I replaced logic board
Just replaced my logic board and everything seemed great.. got my Mac out of the dark and running again but fans are at full speed. Tried ssd fan control also with no luck. All connections seem ok.
any help greatly appreciated
Update (01/29/2019)
its all connected as far as I can tell… I literally took it all apart again:(
Frustrating cause it’s works great otherwise.
i may just have to run the fans with the Mac fans control
Это хороший вопрос?
The SMC thermal sensor must be damaged on this logic board. At this point I think it would be smart to get a replacement logic board as this one is damaged.
Did you apply a fresh coat of thermal paste on the CPU/GPU chips? If you did what thermal paste did you use and are you sure you didn't over do it or damage the logic board in the process?
из Dan
I don't think damaged the board as I was very cautious during the repair. The board is new from IFIXIT so maybe I will see what they say about a warranty board. The thing works fine once I get the fans under control.
Thanks again
из scott robertson
