This is a humidifier with the an R2-D2 theme and appearance. It is produced by Emson.
Where can I get a replacement cord?
We lost the power cord to our R2D2 humidifier.
Where can I get another one?
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
You can try a variable ac-dc power adapter then set it to the rating. This is the information I could find in a manual on google.
I’m not sure if the dc connector from this one will fit, you will need to find out the size of the end connector.
https://www.amazon.com/OMNIHIL-Adapter-C...
“ To avoid fire or shock hazard, plug the AC Adapter into the humidifier then plug the humidifier direct to a 120 VAC or 240 VAC electrical outlet. “
Please reference the manual before executing anything. Remember V=IR, P=IV, https://www.sharperimage.com/si/pdf/manu...
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Grrrouch64@columbus.rr.com буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 6
За последние 30 дней: 10
За всё время: 498
