iRobot not stopping at Dual Mode Virtual Wall Barrier
My iRobot is no longer stopping at my Dual Mode Virtual Wall Barriers. It will also not return to Home Base
Это хороший вопрос?
Это хороший вопрос?
In my case the sensor inside the roomba (the clear acrylic round thing on the front) had one of its cables cut. I repaired the cable (took me 10-15 min) and it started working again.
Был ли этот ответ полезен?
Thanks, that was my case too.
I had the same issue on my 2017 Roomba 980. The red wire of the three sensors on the IR Sensor was cut about 3/4" from the sensor body. I was still able to strip and solder-splice the wire back together and wrap a piece of elec. tape around the splice. This seems to be an issue with some of these. iRobot support was useless. Before a internet-researched what it could be, all they would offer me was a return to repair facility for $132 plus tax and shipping each way or purchase a new one with no discount or rebate for a return. I will never, ever purchase another iRobot product because of their lack of reasonable support. By the way, a new IR Sensor for this device can be had for less than $25 on Amazon so if it fails for this reason again, I'll buy a new sensor and do two more dis-assembly steps to replace it from the PC Board to it's mounting position.
What color of wire is in the middle? my black and red wires where cut off. only the white wire is left connected which was one of the sides. thanks in advance.
If a Virtual Wall® is not keeping Roomba confined to the desired areas, use the following procedure.
If Roomba will not return to its Home Base®, please use the following procedure.
If Roomba is picked up and moved during a cleaning job, it will not be able to find the Home Base when the Dock button is pressed, unless it is placed facing the Home Base within 6 ft (1.8 m) of the Home Base.
If Roomba is going past the Dual Mode Virtual Wall, ensure the Dual Mode Virtual Mode is set to Virtual Wall mode (not Halo mode) and the beam is facing the direction of the area you desire to have blocked off.
Should any of these steps not work, please contact iRobot Customer Care.
My issue was the same only the black wire was broken on mine. Had to take the whole thing apart to fix it. Works fine now. Docks itself and senses the virtual wall barriers again
За последние 24часов: 5
За последние 7 дней: 69
За последние 30 дней: 284
За всё время: 5,580
1 Comment
Could you fix this? I have the same issue.
из Leonardo Horovitz
