The first model of the iMac line of personal computers made by Apple. The iMac G3 was produced between 1998 and 2003.
92вопросов Показать все
iMac G3 password/login issues
I bought a IMac G3 at a resale shop. Turns on but can't login due to not knowing password. I love the bugdom game on this computer and need help to bypass this password to be able to login
Это хороший вопрос?
Оценка 0
2 Комментариев
Do you know what version of Mac OS is running on it?
из
I think 9.0. I pushed the restart button on the side then the other button bedside it and nothing happens...just a blank screen.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
I wrote about this a while back on my blog, hackaddict, but it was such a popular post I thought I’d give it a revisit. A lot of people buy used Macs, and they often run into the problem of not knowing the admin password, so here is a way to get around not knowing the admin password on Macs.
To reset your OS X password without an OS X CD you need to enter terminal and create a new admin account:
  1. Reboot
  2. Hold apple + s down after you hear the chime.
  3. When you get text prompt enter in these terminal commands to create a brand new admin account (hitting return after each line):
    • mount -uw /
    • rm /var/db/.AppleSetupDone
    • shutdown -h now
  4. After rebooting you should have a brand new admin account. When you login as the new admin you can simply delete the old one and you’re good to go again!
from “https://gigaom.com/2008/06/22/reset-os-x...
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Brenda будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 15
За последние 30 дней: 73
За всё время: 1,843
