The PlayStation 3 Slim is the second version of the PS3 video game console with the original model number CECH-2000. Produced by Sony Computer Entertainment it fixed many issues of the original (fat) Playstation 3. It was released on September 1, 2009.
465вопросов Показать все
Ps3 won't spin or read disc.
I've cleaned the lasers thinking it was a problem with them but a disc wont spin whatsoever. Blue light comes on and recognises the disc is in there but it tries to spin and just shakes a little then stops. I've checked everything I thought it could be and I can spin it with my finger and it spins fine but it just won't do it itself.
Any ideas? I'm lost.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
If you can see the disc shake a little, I would suspect that the spindle motor has a bad spot or has failed. Try spinning the disk by hand when you see it shake. If that “fixes” the problem, then change the motor (if you can find one). Otherwise, replace the optics assembly that includes the motor.
Dan
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
SRLBM будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 6
За всё время: 77
