How to determine if digitize has 71 or 90 pins?
Hi, I was given a Amazon Kindle Fire HDX 8.9 3rd gen and it needs a screen replacement. I am reading that there are two different digitizes. One with 71 Pins and one with 90 Pins. Now my question is how can I determine which one mine as without opening it? Is it possible to determine which amount of pins it has without opening it?
Это хороший вопрос?
2 Комментариев
Hi @dudefoxlive ,
Wondering if you search online for the digitizer, using the model number found on the back cover of the tablet, rather than the "name" of the model, to get the correct one would work, e.g. Kindle (insert model number) digitizer (or LCD screen if that is what you mean).
из jayeff
@jayeff
I'm sorry. I did forget to add that. It an Amazon Kindle Fire HDX 8.9 gu045rw. I hope this is helpful as i actually want to fix this and use it for viewing PDF's and such. Also can i order just the digitizer and remove the old LCD and move it to the new Digitizer or do I need to purchase a complete set already put together?
из Dudefoxlive
