Can you upgrade the ram on the Surface pro 6?
i was asking to see if i can upgrade the ram on the Microsoft surface Pro 6?
Это хороший вопрос?
Это хороший вопрос?
The Surface Pro design includes RAM that’s soldered to the motherboard, and so without major “gut renovation” this cannot be accomplished.
Был ли этот ответ полезен?
You can’t add RAM. But that might not be your problem. You’ve probably maxed out your hard drive, like my wife, and so the computer is bogged way down and slow. On the back of the case, under the FLAP, there is a micro-SD card slot. You can put as big a card as you want in there. I just put a 256gb micro sd card, which doubled the storage for $50. This, coupled with deleting useless apps and files, should make it run faster. When you’re out of RAM, the computer uses mass storage for “Swap files”. This is why this works.
Make sure it's fast though. I bought a SanDisk Extreme with 400GB on Amazon because my drive was always full (Its always on discount). Strangely, since I got it I now somehow got plenty of free storage on my C: drive and don't need it after all, but if I want to load Android on my Surface sometime again I should have no problems with partitioning my storage ^^
The RAM is soldered to the motherboard. So, it would be extremely difficult to upgrade.
how difficult exactly? are there any guides online
За последние 24часов: 15
За последние 7 дней: 61
За последние 30 дней: 259
За всё время: 29,028
