iPhone 6 Cellular drop/searching/no service, and phone get's hot fast.
Hi, since recently i have got a problem with my iPhone 6. The problem is that my cellular is really bad, and does drop a lot, it is a bit like the iPhone cannot connect with Service. Other times it does not even connect and say: searching, or no service. Another thing is that it get’s really hot when the phone is connected to cellular, if i put it in airplane mode with wifi and bluetooth, everything is fine. (This could be because it needs to put in a lot of effort to connect to cellular?)
Anyways, what I have tried so far:
- Change the wifi-flex which connects under the motherboard. (this clearly made a diffrence my wifi is amazing now.)
-Change the left top GPS flex, did not really notice a diffrence after that, i think that was just working fine.
-Change the lightning port, I will replace this again tomorrow because the cellular cable snapped of after i got it off for the 100 time trying to figure out what was wrong.
-Done the usual stuff such as reset, simcard in out, different sim, etc.
I might think it could be the back of my iPhone too, I have read more then once that the back covers function as one big antenna and the plastic between the three parts is isolation, in my backcover a piece of the plastic has broken off, the plastic piece by the lightconector. Anyone who has any thoughts on this?
The last thing it could be is the motherboard cable which goes from the downside of the mobo to the upside. Although I don’t think this is the problem because this is really rare.
Anyone who has any other idea’s which it could possibly be? To me it just seems like one of the antennes (GPS, WIFI, LIGHTNING) is not working (properly) which causes the cellular to be bad and dropping, and disconnecting. Which i thus think will be the one at the lightning (maybe it did not do my replacement right, or the case story?)
any help would be appreciated, thanks in advance! :)
EDIT: Another thing I just noticed is that the 2.4GHZ band is worse then the 5GHZ band. Which is weird because usually 2.4GHZ should be much stronger then 5GHZ.
Это хороший вопрос?
