Installing Windows 10 on new ssd
I recently added a new SSD in the old optical drive slot and use the old HD as additional storage. I had no success with moving the two OS over to the SSD so, I chose to do a fresh install. I have successfully gotten a fresh install of OSx on the SSD and everything boots fine. However, I am now trying to install windows OS on the SSD using bootcamp. I get the partition and everything set up fine but, when I get to the windows installer I am getting the error message “Windows cannot be installed to this disk. This computer's hardware may not support booting to this disk. Ensure that the disk's controller is enabled in the computer's BIOS menu.”
Это хороший вопрос?
3 Комментариев
How are you installing Windows?
из Dan
With bootcamp. I made the bootable USB. Go through making the partition in bootcamp assistant, then letting the computer restart and boot to the USB.
из Matt
@matt1992 - I'm suspecting the format of the USB drive is not correct. It needs to be a exFAT or Fat32.
из Dan
