Why is my display fainting, high brightness
This is what my display shows:
I’ve replaced the LCD, LVDS cable, LCD temp sensor.
I’ve also try plugging in an external monitor and it shows perfectly no signs of the faint image.
When I boot the system display it randomly shows a normal image sometimes but when it does, the system powers off or goes to sleep. I can hit the space bar to wake it up sometimes but once I restart the system, it goes back to the fainted screen.
Could it be the GPU still even though the external monitors shows perfect? Or the logic board? Power supply?
Это хороший вопрос?
5 Комментариев
To be clear the external monitor also has the same faint image is that correct?
из Dan
No the external monitor shows perfectly which is why I’m so puzzled
из Corey
Is it left alone for a long time
из Darkened wolves
Never mind it very old? Or needs a sweep in junk or caehe
из Darkened wolves
Yes it’s early 2009 A1225. Maybe so, i May need to reinstall OS
из Corey
