Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
300вопросов Показать все
MBP 15" 2.66 Ghz Mid 2009 losing time after battery drains
The said MBP resets its system time after a shutdown when the battery is drained. I know some macs have a PRAM battery. Does this MBP (MacbookPro 5,3) have a PRAM battery too? Or can this be fixed by replacing the regular battery (which is not in its best shape, almost 50% of the original charge)?
Это хороший вопрос?
Оценка 1
1 Комментарий
Hi Marco,
Did you discover if this model of macbook pro has a PRAM Battery and if so, where exactly it might be located.
Many thanks,
Darren
из
Добавить комментарий
2 Ответов
Выбранное решение
Sounds like it's time for a new battery and PRAM battery.
Был ли этот ответ полезен?
Оценка 1
Hey Marco,
Yes it should do, It wouldn't be a part of the actually battery as if your actual battery runs out, it wouldn't keep the time anyway.
best thing you can do is safely remove the bottom case and it should be fairly obvious thing to spot.
Enjoy and good luck!
Оценка 0
Добавьте свой ответ
Marco Mustapic будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 1,424
