Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4718 Questions Показать все
Unable to activate iPhone 6
Never came across this before. Iphone won’t connect to my WiFi but still picks up signal. Has been updated and restored but haven’t been successful.
Это хороший вопрос?
по рейтингу 0
Комментарии:
No it doesn’t. It says about it can’t activate the phone and it may need a sim pin in order to activate.
от
will it activate using iTunes?
от
No it doesn’t. Says it could be a sim activation but nothing comes up asking about a sim pin so I don’t know if it’s that. I’ve restored the phone through iTunes but still comes up with this
от
Добавить комментарий
iPhone Battery Fix Kits
Only $29.99
Buy Now
Only $29.99
Buy Now
3 Ответов
Наиболее полезный ответ
What is the History? When was it activated last? Why was it restored initially? Are you sure you are getting Wifi but not connecting to Wifi? Looks like signal is from Data (Sim), maybe try activating with another sim? Usually have a searching or no service if data (Baseband issue)… Is IMEI Clean? need just a little more info on what started it all and some background… Bad NAND programming can also cause it
Был ли этот ответ полезен?
по рейтингу 2
You can reset your phone witch may help.
по рейтингу 0
iPhone 6 unable to activate try connecting your iPhone to iTunes to activate it, or try again in a couple of minutes
if this problem persists,contact apple support at apple.com/support
по рейтингу 0
Добавьте свой ответ
Ryan будет вечно благодарен.
Просмотр статистики:
За 24 часа: 1
За 7 дней: 17
За 30 дней: 89
За всё время: 263
