A1150 will not charge. Can one replace the charging circuit?
I have a used A1150 (eBay) and it has never been able to charge at all. I followed all the troubleshooting guides from Apple's tech pages and went to my local Apple tech store. They switched the Magsafe and swapped the battery. Their battery worked fine but the Magsafe charger still did not work (it holds a very dim green light when attempting to charge). They said it probably was not the logic board but the actual charging circuit. What part(s) would I need to replace the charging circuit? can one replace the charging circuit without soldering?
Это хороший вопрос?
Счет 2
1 Комментарий
Do you mean to say they swapped the left i/o board? (the part with the magsafe board)
из
Добавить комментарий
4 Ответов
Наиболее полезный ответ
yes, the charging circuit should be on the left I/O Board, you can find the repair instructions here - replacing it does not involve soldering.
Был ли этот ответ полезен?
Счет 1
They only switched the Magsafe adapter not the left I/O board. Sorry for not qualifying that. @rab777hp
Great tutorial @bac. i will grab a few tools and find a replacement left I/O board. Thanks!
Счет 0
Are you sure it's not the battery? The computer end of the Magsafe on this model of Macbook Pro glows red when the battery is depleted and green when fully charged.
Счет 0
My bet would be the Left side I/O board. Not difficult to replace, but parts getting hard to come by!
Счет 0
Добавьте свой ответ
Steve 10 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 11
За всё время: 5,996
