Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
456вопросов Показать все
Power Button does not work!
I replaced the keyboard and now every key works except the power button. I can turn on the Mac only by unplugging the battery connector and then plugging in the magsafe.
SMC doesn’t work as well. I also tried all the key combinations in order to get it started but nothing works.
Это хороший вопрос?
Оценка 0
Комментарии:
Who's keyboard did you use? Are you sure you got the correct one?
из
I bought it off Amazon, because i couldn't find the Uk one. Every key works, I'm even typing off the keyboard! It's just the power button.
из
Добавить комментарий
2 Ответов
Hello! Carefully examine the logic board to ensure that you have properly connected all the cables.
Был ли этот ответ полезен?
Оценка 0
What happens when you use the power pads?
Оценка 0
Добавьте свой ответ
Pietro Romanato будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 80
