Presented at the April 2003 New York International Auto Show, for the 2004 US model year, the Prius was completely redesigned. It became a mid-size liftback, sized between the Corolla and the Camry, with redistributed mechanical and interior space significantly increasing rear-seat legroom and luggage room.
15вопросов Показать все
Overall systems maintenance on ‘07 Prius
After how many miles should ‘07 Prius be checked?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
I’d say a used/older car should be checked out by your regular mechanic at least once a year. The reason is that oil should be changed each year (even if the car isn’t used much) for the health of the car. You can use that opportunity to ask the shop to do a check on the car for safety. No need to go to the Toyota dealer though, go to an independent shop that can scan codes properly and has worked on lots of Priuses. For that oil change visit, I’d recommend going to the same shop, not asking at a local ‘Jiffy Lube’/while-you-wait oil change place or a large chain, as those companies will probably tell you you need things that you don’t need.
Был ли этот ответ полезен?
Оценка 0
@chrissm you did not tell us how many miles you have on your Prius. Attached is the Maintenance Manual which tells you what needs to get checked according to the miles that it shows. Toyota Prius Maintenance Guide
Оценка 0
Добавьте свой ответ
Christine maciel будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 187
