White screen after replacement
Hi,
I replaced my screen and followed instructions. All parts were connected as they should. I did the RAM reset, SMC reset, safety mode, etc and still white. I connected it to an external monitor through hdmi and it shows on there. Tried repairing the hard drive and didn’t help. I am wondering if I received a faulty screen.
Это хороший вопрос?
Also try a PRAM reset, that can help with some screen related issues.
https://support.apple.com/en-au/HT204063
из Ben
What happen that you had to replace the old screen? Do you have a means of booting from an external drive?
из mayer
Hi Ben,
Tried it and still getting the white screen unfortunately.
из Kevin Kim
Hi Mayer,
When I replace the old screen, it works still. It’s a cracked screen but I can still see the login screen and lines going across. Also what would booting on an external drive reveal? When I log in using a separate display through hdmi, I log in as usual and I can use my MacBook with no problem. Everything is functioning perfectly except I just can’t do anything with the new screen because it is blank.
из Kevin Kim
Screen is still white after trying all suggestions. What are my options? I am at a loss here of what to do.
из Kevin Kim
