The iRobot Roomba 880 is an autonomous vacuum released in 2013, with greater power and cleaning capabilities compared to the previous models.
9вопросов Показать все
Roomba not picking up
I have had my roomba for about 1 1/2 years. It is significantly quieter than it used to be, and there is no air exhausting from the back vents. It’s still picking up larger debris but does not have much suction. I have cleared out debris from the rollers, filter, bin, and wheels and it didn’t help. Local vacuum repair won’t fix roombas. Any suggestions?
Это хороший вопрос?
Оценка 4
Добавить комментарий
1 ответ
Наиболее полезный ответ
Same thing happening with my 880. Would not pick up lint, just a little sand. After reading on line checked my with my hand and no wind was blowing out of vent. We had a friend that helped us clean everything and determined, we needed a new motor. It is inside and wewould have to buy entire section with filter etc that was $59. He removed 4 screws that allowed him access to the motor and it had lint inside. After he cleaned and vacuumed it out, it would turned freely. Put it back together and suction problem solved.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
jaclyn1713 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 7
За всё время: 753
