Дата выхода 19 сентября 2014 года. Это большая версия iPhone 6 с 5.5-дюймовый экраном.
1525вопросов Показать все
Can't get the phone into recovery mode
I need to restore an iPhone 6 plus with iTunes. I have tried holding down the menu key along with the power button starting with the phone being off and I’ve tried it with it on to start with. I tried holding down the vol down and the power but I still can not get it to go into recovery mode. Any other suggestions would be great!
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
if you are trying to get to DFU to do a restore (this will delete all your data on the phone, not icloud)
1.connect to phone to the pc and open itunes
2.hold Power + Home button for 10 seconds
3.Release Power button but keep holding Home button for 5 seconds or until you hear the pc sound when you connect a device ( if you see the apple logo, you holded home + power too long, repeat step 2)
at this point itunes should detect the phone in DFU and should let you do a restore, this will trigger icloud protection if there is any, make sure you know your password to the icloud account or you wont be able to access your phone.
Good luck!
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Kathline Stewart будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 13
За всё время: 873
