Can't charge anymore the battery
Hello,
I’ve just bought the Xiaimo QiCycle bike, and I was so happy of my purchase.
I’ve ride it to my work for a few time before winter, and I put it in the garage waiting for better days.
The sun comes finaly earlier, and when i tried to charge the battery, nothing works…
I noticed that once connected to the charger, the green led of the charger did not turn red (charging indicator), while the indicator of the bike tells me that it is completely discharged
This green led stay to green, and do not charge the battery:(
Could you tell me what to do to find out if the problem is with the charger or the battery?
Thanks a lot for your responses !
Это хороший вопрос?
14 Комментариев
I'm having the exact same issue. 1 day old bike :(
из w.andrew.lee
the most i was able to dig up is a replacment batery for you..
have you used a multi meter to see what the power reading is coming from the charger?
company doesn’t offer any support or replacement parts that i could find.
replacement battery - https://www.aliexpress.com/item/Lithium-...
из Carmello Castellano
thanks for your response, but it does not answer to my question...
Could you tell me the right state of the charger led when the charger is connected to AC/DC input, but disconnected from the battery ?
Not connected to the battery, this led should be green, red, or turned off ?
из frederic tanchou
Update (03/07/2019)
I managed to recharge part of the battery (60%) by doing the following:
1. connect the charger to the battery
2. connect the charger to the power supply
3. wait for the sound click of the charger
4. unplug the charger from the power supply
5. Repeat steps 2, 3, 4 several times until the red LED starts to appear.
Maybe it will work for you Andrew
из frederic tanchou
Can't seem to get that to work for me. I also bought a new charger and it also doesn't charge the battery :(
When you are doing steps above, are you pulling out the cable from the wall and plugging it back in each time?
из w.andrew.lee
Показать 9 больше комментариев
