MacBook Pro non start no light on charger
Had logic board replaced, now completely dead. Charger does not light up. Charger, & power source good. How can I test to see if this is a battery issue?
Это хороший вопрос?
Это хороший вопрос?
If you have no light on the MagSafe you’ll need to check it as it’s likely damaged Apple Portables: Troubleshooting MagSafe adapters and make sure you are using a real MagSafe charger OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth.
Inspect the systems MagSafe connector make sure the contacts or clean and shiny if not you’ll need to replace the MacBook Pro 15" Retina (Late 2013-Mid 2015) MagSafe 2 DC-In Board follow this guide MacBook Pro 15" Retina Display Late 2013 MagSafe DC-In Board Replacement
Был ли этот ответ полезен?
I think that If someone did replace your logic board you need to check with him first to see what’s the problem because if you try to make your stuff and was the logic board installation there is not way to prove that was a bad logic board installation or the logic board have fail.
Regards
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 70
4 Комментариев
What color is the MagSafe adapter? Amber or Green.
из Dan
You had the logic board replaced or you did it yourself?
из mayer
Have you tried an SMC reset? https://support.apple.com/en-us/HT201295
из Jonah Aragon
No light on charger
I had logic board replaced by someone else
I have tried SMC reset as well.
из Jim McDermott
