The SanDisk Cruzer Glide is USB flash drive with a retractable USB plug. It comes in a variety of storage capacities with a black and red plastic case for all models.
usb unreadble on my tv
my usb which worked perfectly fine on my tv now gets the error of being unreadable on my tv
the only thing i did was i formatted the usb for installing mac osx
then upon reformatting using disk utility
it wont be read on the tv
while it works perfectly fine on my laptop to fop and my tv can read other usbs
i would like to know what would be the issue and how to fix it
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
When you formated the flash drive you messed it up for the TV. You’ll need to review your TV’s manual to see what formats are supported. Most only support FAT32 or exFAT.
Mac’s also supports these formats for data drives, but for boot drives and when you want Mac’s file security you’ll need MacOS’s GUID format and either HFS+ or APFS file systems.
After saving anything important on your drive you’ll need to reformat it and this time I would select exFAT so your TV can access it.
Here’s more on the differences:
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Dhanyy dhanish будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 134
