Представленный 3-его марта 20 17 г. Nintendo Switch- это портативная приставка, способная устанавливаться в док-станцию и выводить картинку на TV
153 Questions Показать все
Nintendo Switch not turning on
On a USB Ammeter it displays 0.46A and constantly stays there.
Opened up device and found battery was pretty much flat. Charged it up around 3.7-4.2V and attempted to turn it on with the battery connected once the battery was charged up externally at that voltage.
It still did not turn on and charger still reports 0.46A. No signs of liquid damage on board as inspected under microscope.
I would suspect charging chip but isn’t it supposed to turn on with a charged battery if that was the case and not charge?
Это хороший вопрос?
по рейтингу 1
Комментарии:
Unfortunately, this is one problem I've never found the fix for and I don't know of anyone that has. I don't think there is a fix for it at this point.
от
I noticed that BQ24913 (Lower bottom left pins) and the cap next to it becomes shorted to ground when I plug the battery in so I may replace that chip and see how that goes.
от
Did you use a 3rd party dock? I think that that still happens.
от
I'm doing this for a client so I would have to ask them whether they did or not.
от
Добавить комментарий
PC Laptop Batteries
Batteries for all the top PC brands, backed by our Quality Guarantee.
Купить сейчас
PC Laptop Batteries
Купить сейчас
1 Ответ
Do a hard reset. Hold down power and volume Button at the same time. My switch would not turn on I did this and it worked. If it does not work charge it. If it still not working send it in for a repair
Был ли этот ответ полезен?
по рейтингу 0
Добавьте свой ответ
Ben будет вечно благодарен.
Просмотр статистики:
За 24 часа: 2
За 7 дней: 2
За 30 дней: 27
За всё время: 101
