The Samsung Galaxy J1 Nxt (also called the J1 mini) is an Android smartphone released by Samsung Electronics in February 2016.
5вопросов Показать все
Why does my screen go white sometimes
Screen goes white on my j1 mini and i have to take out the battery and put it back in to get it to work again. Can't switch it off even.
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
If the screen goes completely white, but re-seating the battery helps, then the issue may be with the phone’s software. Have you tried performing a full factory reset on the device? Doing this will revert your phone’s settings back to the state they were when you first received it, as well as perform any software updates.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Julie Growden будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 9
За всё время: 387
