The Kia Optima is a mid-size car produced by Kia Motors beginning in 2000 and marketed globally with various names. Firsts-generation cars (2001-2005) were generally sold as the Optima, though the name Kia Magentis was used in Europe and Canada when sales in those regions began in 2002.
50вопросов Показать все
2005 Optima hose or thermostat issues
I noticed that the top hose from the radiator to the engine drips by the engine. Just a little. What the chance the hose need replacing or the thermostat?
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
Frank take a look at the picture on your other question. It appears that there are two hose connectors and the thermostat on the side. It is hard to say which part is leaking but my first gut reaction would be that it is the hose. It is far more exposed to the elements as well as movement. The thermostat should sit snug in the housing. Again, a bit more of a visual inspection might give you the answer. Good Luck
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Frank будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 733
