The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
Вопросов 20 Показать все
Ipad won't connect to home wifi
All Apple devices will not link up to home wifi. Changed password wifi and still no connect. Rebooted system and reset Apple products network system and no connect. Advices wifi password is wrong. All other android devices connected no problem.
Это хороший вопрос?
Оценка 1
1 Комментарий:
"No connect" is too vague; more details and information is needed. Are you getting an error message? Is it not seeing the network? You say "All Apple devices" but specifically call out just an iPad 6; is it just a single iPad or are there other devices that can't connect? Can they connect to other wifi networks?
из
Добавить комментарий
Ответов (2)
Hi,
  1. Go to settings (app)
  2. Then select “General”
  3. Scroll down and click on “Reset”
  4. Now click on “Reset Network Settings”
  5. Go back to “WiFi”
  6. Select your WiFi
  7. Re-enter password
Был ли этот ответ полезен?
Оценка 0
common problem check ur wifi conection with another apple device if conects then safe mode ur ipad and delete the most recent app u installed or update it and then boot up as normal also reset ur wifi
Оценка -1
Добавьте свой ответ
roroeow7 будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 490
