Released in 2015, the all-in-one camera featuring WiFi, Bluetooth, and waterproof capabilities. This camera lacks the touch screen display of the Hero+ LCD.
10вопросов Показать все
battery life and won't record past 5 seconds
tried all types of sd cards. won’t record past 5 seconds. keep getting sd card formatting error. i have the sandisk extreme pro 32 gb. reformatted and still the same problem. can the camera be repaired? also battery life is short.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Hi, the SD card slot could have a problem internally with it so you may need to get that fixed here is GoPros contact link: https://gopro.com/help/ContactUs. The battery if you can remove it may be old and dying. Rechargeable batteries only can live so long so you may need to order a replacement one for it. I had this problem with my Hero 5 Black, I ordered a new battery and now its fine. Hope this helps, have a good day.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
rene ruiz будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 6
За всё время: 138
