Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
456вопросов Показать все
Can anyone help me figure out why my 3DS isn’t charging?
When I plug the charger in the device (the one that came in the box with the device) the orange light comes on for a few seconds and just goes. When I press the power button, nothing happens. I purchased this 3DS in 2011 also. Can someone help please?
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
I don’t own a 3ds but from my research let me suggest a few repairs: 1. try taking out batter and putting back in. 2. Take out ur game cards and memory to prevent damage to them. ( I damaged my ps vita memory card by not doing it) 3. Try cleaning Charging port and battery contacts. 4. Try leaving 3ds on charge overnight 5. Last resort would be to disassemble ur 3ds and check all the components with a multimeter or if u don’t have one try unplugging and repluging all modules and wires and make sure every thing is properly connected i suggest taking a picture of internals before disassembling anything. Hope it helps
Был ли этот ответ полезен?
Оценка 1
I had this problem too, My 3DS would not charge when the cable was plugged into the back port or even when it was in the cradle. You could try and identify the problem yourself by following tutorials on the internet and looking at other's experiences, or you could take it to an electronics store. The thing about getting your 3DS repaired, however, is that some stores will unfortunately not be able to do any repairs at all. For example, I went to a nearby Best Buy but due to the console's age they didn't have parts. Ultimately I ended up getting an external charger to charge one of the two batteries I had, and then swapped them out when needed. But be careful, it's a huge pain if you accidentally strip the screws on the back. Hope this helps!
Оценка 0
Добавьте свой ответ
my3DSneedshelp будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 84
