1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
371вопросов Показать все
Can I mount a Samsung 970 EVO PLUS?
Hello, I have a Samsung 970 EVO PLUS m2 drive and I’d lik to know if a compatible adapter exists for my Mac! I already tried this but i can’t connect the ssd to it
https://m.imgur.com/gallery/buQOeYi
Any clues? Thanks
Это хороший вопрос?
Оценка 0
2 Комментариев
Sadly on this specific model there are no good solutions as all the Toshiba SSDs go bad on the mid 2012 airs.
из
I would install either the OWC or Transcend SSD instead.
из
Добавить комментарий
1 ответ
Выбранное решение
Your MacBook Air uses a custom Apple connector system. M.2 SSD’s won’t fit directly and I don’t recommend using M.2 adapters as I’ve had to replace quite a few setups with the correct SSD as the M.2 SSD tend to burn out from the heavy CRC errors they encounter in this config. Yes, they look like they work but over time they fail!
You also have a second issue here which is what the system can support for a SSD. There are three different interfaces
Lets review what your system uses here The Ultimate Guide to Apple’s Proprietary SSDs - Gen 2 So your system only uses the Red mSATA interface on the left.
So the Samsung970 EVO Plus is just not compatible!
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
so which ssd you recommend for upgrading a macbook air 2017 (A1466)?
из
I would go with either OWC or Transcend SSD's or stick with a larger Apple SSD BeetsTech
из
Добавьте свой ответ
tyronefromhell будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 9
За всё время: 3,930
