Repair guides and support for a wide range of sound cards.
3вопросов Показать все
Annoying static noise on realtek integrated audio
This has been an ongoing issue. The problem got temorarily fixed when It automatically installed an nvidia sound driver along with my video card, however after rebooting the problem promptly returned. Here’s whats going on: https://www.youtube.com/watch?v=FbOHncQs...
Before any of you ask, Yes I’ve tried reinstalling the driver, Yes, I’ve tried disabling the realtek driver and it refused to use the nvidia one.
Это хороший вопрос?
Оценка 0
Комментарии:
Is nobody going to help?
из
When does this sound happen? Right after you power on your computer? Is it still there if you mute the sound with software? Does it ramp up according to your volume control? Does any other sound play, or is it only always noise?
из
Going to record and upload a video. It starts shortly after booting into windows then goes away when it starts shutting down. I am going to set the speakers to full volume in the video so you can hear it.
из
Did something change for this to start happening? Software install/update? Does any other sound play other than noise?
из
Показать 4 больше комментариев
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi @connor2003
good day
please list down your pc components, e.g. using laptop or desktop.....
if using desktop please list down the parts...
e.g. power supply, etc
sometimes this issues, can be due to some issues,
e.g.
OS issues,
Power supply not clean
soundcard issues
mainboard issues
grounding issues
try running for a long run with a linux live cd, and play some music for an extended time... are there any distortion?
Был ли этот ответ полезен?
Оценка 1
Комментарии:
Dell Inspiron 3847 with stock oem dell motheboard
Intel core I5-4460@ 3.20 ghz
8 gb ram
Sandisk SSD plus 240 gb
EVGA gtx 1050
EVGA 750 N1 750 watt power supply
The sound card is built into the botherboard
the power supply, ssd, ram, and graphics card are brand new.
из
Hi Connor
Suggest you to update bios and test run in a "live linux environment"
https://www.linuxliveusb.com/
http://www.knopper.net/knoppix/index-en....
из
How is that supposed to fix my sound issues? For security reasons, I am not going to do that.
из
I end up buying a dedicated or external sound card to avoid the static noise issues.
из
Добавьте свой ответ
Connor будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 8
За всё время: 450
