Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Google's 2nd-generation Pixel XL sports a 6-inch P-OLED display with rounded corners. Available in 64 and 128 GB storage configurations, and in two colors: Just Black and Black & White. Released October 19, 2017.
61вопросов Показать все
4G Randomly disconnecting after screen and charging port replacement
Hey, after replacing the screen and charging port on my Pixel 2 XL my cellular data has kept disconnecting. Did i do something wrong? Do i need to open to phone again to fix or buy new parts? Here is a screenshot from the status bar when it disconnects
Это хороший вопрос?
Оценка 0
Добавить комментарий
OPEN ALL THE TABS
RAM Upgrade Kits for Mac
Shop Kits
Enough RAM
For All The Tabs
Shop Kits
2 Ответов
Наиболее полезный ответ
You might want to open the phone again and try reconnecting the connector for the new charging port. Also try rebooting it a few times. The Turn off and back on thing is very old fashion but sometimes it works! Best of luck!!
Был ли этот ответ полезен?
Оценка 1
I had a similar issue with my Galaxy S4 a few years back, when I first started getting interested in repairs. I had accidentally snapped the head off the antenna so it obviously wasn’t connected. I only realized it when my signal was crap and I had to buy a new antenna. It may also be due to the charging port connector as Ian Shalongo said.
Before you go ripping your phone apart though, you should try a few things…
Try rebooting the phone.
Check for any updates. Many Pixel 2 owners had signal problems that needed an update to be fixed.
Try basic trouble shooting steps like popping the SIM out and back in, resetting network settings, etc. There is a really good guide for
https://thedroidguy.com/2019/03/how-to-f...
Good luck and God Bless
Оценка 0
Комментарии:
I have tried the basic steps like taking out the sim and rebooting it multiple times and even done a factory reset on the device without any luck. I think im just going to buy a new display adhesive and rip the phone open to see what i did wrong.
из
Did you reconnect both ends of the antenna wire along the right side of the phone?
из
Добавьте свой ответ
Mico Hautaluoma будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 31
