Unit has power but stopped cooling
I have a whirlpool refrigerator stop just stopped cooling and when i open the door the inside lights don’t come on. But the front panel for the ice/water maker have power. i heard a clicking sound in the bottom of the unit, i opened the back and found that the 3 way coil relay was making the sound. I unplugged that unit and plug it back in and the unit started to work again. I am just not sure if this part might be going bad or if resetting this part reset some other thing that its connected to. Any help would be greatly appreciated.
Это хороший вопрос?
Оценка 0
2 Комментариев
what is your model number?
из
Whirlpool - WRF767SDEM01
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
I am unable to determine the part you are talking about from the description. Here is a list of all the parts for your refrigerator:
https://www.repairclinic.com/Shop-For-Pa...
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
The part that was clicking was the 3 way coil that sits on the 3 way value. I believe there is 4 wires attached to the coil.
из
Добавьте свой ответ
[deleted] будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 192
