Обновленная версия iPhone 3G с более высокой скоростью обработки. Ремонт этого устройства схож с iPhone 3G, и требует простых отверток и инструментов для вскрытия. Модель A1303; 16 или 32 ГБ памяти; с Черной или Белой задней пластиковой крышкой.
1958вопросов Показать все
Power button is not working - how to fix it?
Hi,
in iPhone 3GS, the power button is not response.
You press it but no action. The phone felt down to the floor many times.. My question is: What could be the way to fix it? what attached to this button? I know that there is a flex reibbon (Gold cable) that attached to the power button, earphones, volume buttons and it is not easy to fix. That's the only part that affected not working power button? That ribbon?
tnx
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
Yes, that ribbon. The Headphone Jack Ribbon Cable #5. A short term fix that sometimes works, is to squeeze in that corner the front screen and back case together (pinching) while pushing the button. When you repair the 3GS, make sure it is OFF before and during all repairs.
Был ли этот ответ полезен?
Оценка 1
Комментарии:
How can I know what is #5 cable? Where are the numbers of these cables? Is there a table of it? thanks
из
And could you please add a link of picture of that part?
из
pintching did not work. So what could be the problem? and what is the solution?:) The vibrate button,headset hole, and the volume button are working.
из
i phone off but on no respons age on celo now on way
Оценка 0
Комментарии:
not quite sure what is going on with your phone. Give us more information.
из
iphone 3gs no on now but age on celo others on way
из
Добавьте свой ответ
Shai будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 28,897
