Repair guides and support for motorcycles manufactured by Suzuki Motor Corporation.
110 Questions Показать все
Slipping after I been riding for 20 mins and it heats up
Okay so i have a 1995 rf900r and kts been running fine until recently.. Now when i first start the bike and ride it will run through all the gears fine but after 20 minutes or so no matter what gear im in if i apply too much throttle the bike will just rev and not take off .. However if i apply the throttle slowly i runs fine in all the gears this is only happening after the bikes been running for 20 minutes or so its my first bike and im not sure what it could be please help….
Отвечено! View the answer У меня та же проблема
Это хороший вопрос?
по рейтингу 0
Добавить комментарий
iPhone Battery Fix Kits
Only $29.99
Buy Now
Only $29.99
Buy Now
1 Ответ
Выбранное решение
Clutch pack is probably on its way to used up. You should find someone with right tools and expertise to replace it. You could also acquire the tools and knowledge to do it for yourself if you are willing to learn why the shops charge so much to do this job. A second possibility is that there is not enough freeplay (or maybe even no freeplay) in the clutch actuation mechanism and that is causing the slippage as the clutch pack heats up to (and probably beyond in your case) operating temperature. A simple adjustment might restore the clutch to normal operation but don’t expect it to last forever if such an adjustment “fixes” it. All the burnt lining contamination in the oil is not very good for the rest of the internal parts… stopping up oil filters and impeding oil supply is a big concern. Or maybe you have this problem… https://www.youtube.com/watch?v=D-KThaAZ...
Был ли этот ответ полезен?
по рейтингу 2
Комментарии:
Hi,
To add to the answer, here's a link to the service manual which may be of some help.
от
Добавьте свой ответ
Phil S будет вечно благодарен.
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 18
