Смартфон был выпущен 26 октября 2018 года с разными модулями связями и количеством SIM-карт. Модели A1984, A2105, A2106, A2108 были доступны с GSM или CDMA/eSIM, nano-SIM или dual-SIM. Объём памяти варьируется в пределах: 64, 128, 256 Гб. И, конечно, iPhone XR увидел свет в различных оттенках корпуса: черном, белом, синем, желтом, Coral и красном.
468вопросов Показать все
iPhone XR | Cracked screen, Front Camera Not Working, Face ID Works
Got an iPhone XR in the other day for a screen replacement. The screen was dropped and whatever it fell on, made a pretty nasty crack directly over the front camera lens. After changing the screen, I wasn’t at all surprised to find that the front camera also did not work, well, sorta. ..
When you open the camera app, the front camera is only black. Rear camera works. Face ID works. Proximity sensor works. Knowing that Face ID would no longer function with a replacement front camera, the customer opted for a front camera replacement.
I replaced the front camera and nothing changed except for the lack of Face ID. Front camera is still black within the Camera app.
I then reinstalled the original camera and then performed a DFU mode restore on the iPhone, but this also did not fix the problem.
Any advice?
Это хороший вопрос?
Оценка 0
1 Комментарий:
i think it’s a board level reapair (micro soldering )
из
Добавить комментарий
1 ответ
I understand that this may be very frustrating so I’ll try my best to help you. This situation is very weird. The drop may have somehow damaged the logic board if it did you’d have to buy a new iPhone Xr because this part is very hard to repair has it is the motherboard of a phone. I can see two more solutions one is to take caned air and air down the internals. The next solution is to attempt to repair the rear camara.
Hope that this helps you.
-Noah Byrum
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
TechWizard будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 9
За всё время: 2,558
