Cut electrical wire cord for A1243
I need to know how to replace the cable or repair it.
Это хороший вопрос?
Это хороший вопрос?
If it is an USB cable that was cut then you should open your keyboard and re-solder a new cable to the PCB. Please mind to properly connect polarity of the USB power supply and Data cables. It will be 4 wires + ground so if you are handy with soldering iron then you should handle with it.
Был ли этот ответ полезен?
then finish your %#*@ teardown and fix it while your doing it
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 17
За всё время: 1,446
