The Sony Xperia Z is an Android based phone that was released in 2013. It is one of the largest phones of the Xperia family with a 5-inch full HD display. Model numbers include C6603/C6602.
97вопросов Показать все
Battery charge level jumps from 10-15 to 0 literally in one second!
Hi everyone! I have used my phone since 2014 (maybe, since 2013). I never ever had any problems with it. And in the case I had, I just updated the firmware. But now I face some problems. It overheating all the time. For instance, I write a text with a simple app (I write essays for money), and in a few minutes, it gets overheated. All other applications are closed (and almost nothing works in a background mod). Or, I scroll messages in Telegram (which is also a simple app), it starts to lag and overheated also. But the main problem is when I have 10-15% of the battery charge level. It jumps to 0 literally in a second (it's so unexpected) and turns off. Do you have any suggestions on how to fix it? I have limited free memory space, may it cause such kind of problems? As I know, overheating is because of processor or when you're out of RAM, not ROM.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Hi Janet Daetton
All batteries, regardless of type will experience something called voltage sag. Heck, you even see this with your AC power for your home when the lights dim for a split second whenever something like the air conditioning kicks on and draws a lot of power.
In short, any time a demand is placed on the battery, the voltage will drop for a bit. This is natural and to be expected, but the amount of voltage loss is minimal on a healthy battery. As a battery ages and the internals breakdown, the amount of voltage loss increases. The amount of demand you put on the phone affects this as well. I.e. Gaming would result in more of a voltage sag than just sitting idle.
What makes Li-ion batteries unique is that they can not be discharged to 0 volts and then recharged (at least not without special care and equipment, and even then it's not guaranteed). 0% on your battery gauge is not zero voltage. It's the lowest the battery can go and still be safely recharged.
So what you are experiencing is what happens when these two issues intersect. As your battery gets low, something is putting a power demand on the weakened battery that causes the voltage sag to dip below the cutoff point. When this happens, it's an instant shutdown as if you pulled the battery. This usually isn't noticed at first because it may start at 5% or so, which most people would've already plugged in before then. It'll only get worse from there. So you keep using your phone not knowing this is getting worse and worse, except maybe for shortened usage time between charges, until it finally starts sagging so much that the cutoff happens before you'd plug it in.
Hopefully this helps clear it up for you. As a side note, this instant shutoff is what Apple was trying to avoid when they started slowing down their phones with weak batteries. By throttling performance, the voltage sag wouldn't be as bad, letting you keep using the phone longer without the instant shutdown. Not that this is necessarily a good thing, as Li-ion batteries hate being deeply discharged and letting people keep doing so like this could actually speed up the degradation.
Thanks and Regards
If you face any kind of password related problem in future on you’re Android , iOS & Windows device you can contact Password Recovery Support.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Why put spam at the end of a good response?
из
Hi
Battery charge level jumps Plug the other end of the Car Charging Adapter into the Input Port of the Jump Starter.
Plug the USB Charging Cable into the USB 5V / 2.1A Output Port of the Jump Starter.
Select the appropriate connector for your mobile device and insert it into the charging port of your device.
Thanks & regards,
baby breathing monitor
Оценка 0
Добавьте свой ответ
Janet Daetton будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 10
За всё время: 693
