My battery is very low is their a fix for this
I have closed apps and checked any possible drainers on the watch but it still goes dead in less than 6hrs??
Это хороший вопрос?
Это хороший вопрос?
Hi @mystique28 ,
Try changing the battery first and check the watch’s performance. 2-3 years is a reasonable lifespan for a small rechargeable battery.
Here’s a link to the ifixit Asus ZenWatch 3 Teardown guide. This should be of some help to gain access to the battery so that is can be replaced.
The battery model number is C11N1609.
Here’s a link to just one supplier. It is shown only to give you an idea of the cost of the part. There are other suppliers online that may suit you better.
Just search online using the model number of the battery only in the search box of your browser to get results for suppliers of the part.
Был ли этот ответ полезен?
This is very helpful.
Thank you
You should check the battery. This can happen because several reasons. it s lifetime might be about to end. Make sure to block unnecessary notification ,adjust the brightness level and turn off wifi syncing. These are usually save the battery life.
How do i turn off wifi syncing and if its the battery is their a guide to change it?
Where can I get a C11N1609 battery to buy
Asus has d/c'd the battery. You can find them on ebay
@thomeward On ebay
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 5
За всё время: 886
2 Комментариев
Hi @mystique28 ,
Just verifying that you have checked the screen setting to ensure that it is not set to always on?
How old is the watch? Even rechargeable batteries have a lifespan.
Just some thoughts.
из jayeff
Hi no the watch has a screen time limit i think its about 2 to 3 years old now
из Tracey Homeward
