The Latitude E7440 is an ultrabook by Dell released in November 2013, identified by model number 730-6964, with a fully usable touchscreen display. It is a high end business laptop built to be portable and sleek yet sturdy.
14вопросов Показать все
Вопрос закрыт
Black screen on boot, no backlight BIOS reports “unknown panel”
I’m having a problem with the screen, it never turns on, the last time it was on it went blank white(which is also what it does when I try to run the lcd built-in-self-test), then never came on again, the bios says “unknown panel” I’ve replaced the screen cable but it still doesn’t turn on, and the bios still says “unknown panel”, could the panel have failed?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
If BIOS is not recognizing the LCD panel, perhaps flashing the BIOS to update it will help.
Also, is BIOS giving any “beep codes” when you first turn your computer on?
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
I’ve already tried this, and it made no difference, no it functions normally other than the screen not working, thanks for the help though
из
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 366
