The QiCycle Folding Electric Bike is Xiaomi’s first foray into the world of e-bikes. It has a 250W high-speed motor powered by Panasonic 18650 lithium batteries. The Shimano Nexus 3-speed gear hub in combination with the torque measurement sensor gives you up to 45km bike power on a single charge. It also has a trip computer can connect to your smartphones via their special app and is–of course–foldable.
54вопросов Показать все
Why battery is 100% but display show me 0%?
Hello,
I don't know why but suddenly my qicycle stops to work… The battery is charged but the display show me 0%.
I tried some solutions like disconnect and reconnect torque cable and try to update by official and unofficial app the firmware but It doesn’t work.
When I try to upgrade the firmware, the process failed every time and I tryed few times.
I don't know really how to solve the problem, please help me!
thank you very much!
Это хороший вопрос?
Оценка 2
Добавить комментарий
1 ответ
I have the same problem. Did you find the solution?
Был ли этот ответ полезен?
Оценка 0
3 Комментариев:
I found it. In my case it is a broken cable into the ankle brake point of the cycle. I replaced it and it works just fine. Open the ankle and check the cables.
из
Can you help me? I have the same problem
из
Can pin point where is the ankle brake point of the cycle? Thank you.
из
Добавьте свой ответ
agrotheclown будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 8
За последние 30 дней: 28
За всё время: 559
