Руководства по ремонту и информация о разборке автомобильного зарядного устройства Anker PowerDrive с 2 портами.
Reversely connect and didn't work after that
I mistakenly while I was fixing the charger house in the car, I connected Anker power drive+2 reversely then I recognized that the connection is wrong .
I have corrected it but after that Anker power drive+2 did not work.
Any one can tell me how can I repair it, Please
Update (06/12/2019)
Hi Jafeff,
Thank you for reply and help
I am attaching here a pictures of the charger and hope if anyone can help.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Hi @mnaqil ,
reversing the polarity of the supply would have possibly damaged (destroyed) some components on the circuit board
Post some close up pictures of the circuit board from the device back here and maybe someone can spot the problem.
If not you'll need to trace the circuit from the input through the components using an Ohmmeter etc to determine which component (or components) are faulty.
Hopefully it will be something obvious.
Был ли этот ответ полезен?
Счет 4
5 Комментариев:
Hi @mnaqil ,
Use an Ohmmeter and check if component F1 is OK and has not blown. It is a bit hard to tell from the picture.
Usually F is the designation for a Fuse.
Also check that D1 (diode) is OK and not open circuit. Diodes normally test low resistance in one direction when using an Ohmmeter and high resistance in the other direction when reversing the Ohmmeter's test leads across the component.
из Поделиться
Hi @jayeff
Thank you for your answer.
I have checked the fuse F1, it's burned. For the diode D1, it's working normal as you said, from one side it's value was 0.7 KOhm and on reverse it gives 23 MOhm.
Is there any suggestions for fuse replacement as there's no information written on it? What if I bypass it?
Regards
из Поделиться
Hi @mnaqil ,
Bypassing the fuse will expose the rest of the device to more damage if there are further problems on the board.
Measure across the input to the device with an Ohmmeter (with the fuse bypassed - shorted out) and check that you don't read a short circuit as this will blow the new fuse immediately.
If you read open circuit then another component has burned out and you will have to do point to point testing with the Ohmmeter until you find out where the open circuit is
The specs state that it has 2 outputs of 1.5A each so therefore the fuse has to be able to carry at least 3A with an input supply voltage of 12V.
I suggest that you look for a supplier of this fuse.
0438003.WRA - FUSE, AEC-Q200, FAST ACTING, 3A, 0603
Not sure if it will physically fit as I don't know the spacing between the F1 solder pads on the board.
You can check on the datasheet (scroll down to dimensions) to see if it will fit.
If it is suitable get 2 or 3 ;-)
из Поделиться
Hi @jayeff
I have replaced the fuse and now it's working properly.
THANKS ALLOT
Regards
из Поделиться
Hi @mnaqil ,
Good news.
Thanks for the feedback.
Cheers
из Поделиться
Добавьте свой ответ
Akil буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 36
За все время: 849
