Heart rate sensor glass cracked
The glass panel over the series 4 heart sensor has cracked, I see the only way to repair it is to completely replace my watch. Is there away I can get only the back glass replaced?
Это хороший вопрос?
Это хороший вопрос?
1: Nobody sells that part, also it is fused with the sensor, it is not possible to replace just the glass.
2: You’ll be gutting the watch front to back to replace the rear cover assembly. If you need to ask whether it can be done, you can’t do it. You will wreck it for good.
3: I’m not sure if Apple randomly implemented any security pairing to disable swapped parts.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 10
За всё время: 4,708
