The Kenmore Elite HE3 is a washing machine by Kenmore.
669вопросов Показать все
Kenmore washer will agitate and drain but won't do final spin cycle
My Kenmore front loading washer will agitate and drain but won't do final spin which leaves the clothes dripping wet. There is also a buzzing noise when it's trying to do the final spin but not anytime other than that. The belt looks in great shape, the machine still agitates, just won't do it normal fast spin at the end. Could this be the wax motor part of the door locking mechanism?
Это хороший вопрос?
Оценка 0
1 Комментарий
its a Top loader
из
Добавить комментарий
1 ответ
Выбранное решение
Cause 1
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not spin. To determine if the lid switch assembly is defective, use a multimeter to test the lid switch for continuity. If the lid switch does not have continuity, replace it.
Cause 2
Motor Coupling
The motor coupling connects the motor to the washing machine transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
Cause 3
Drive Belt
Inspect the drive belt to determine if it is broken or if it is loose on the pulleys. If the drive belt is broken or loose, replace it.
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
where is the drive belt located?
из
Добавьте свой ответ
Brandon будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 16
За всё время: 2,990
