Lock button clicks but doesn't work
IPhone 3G on off lock button switch clicks but doesn't do anything. It wont sleep or power off so reseting it isn't an option. So how else can it be powered down/sleep? it was dropped so bad that the metal frame is coming undone from the back casing, you could probably pry it open from that corner. What do I need to do to get the lock button working again? Seems to me that something either came undone or possibly disconnected inside? Again it clicks and looks like it should work so it must be inside. Doesn't seem like I need to replace the button at all but not sure how to fix this. Please Help Please?!!!!
Это хороший вопрос?
4 Комментариев
Pinching it doesn't do anything either could something of gotten lose inside? Ive never tried fixing this so nit to sure about how to go about getting to it I mean i can get the screen off but thats about it. so what should I do what would you do to try and fix this?
из Ryan
also since i cant power it down should i wait till it dies before i open it?
из Ryan
It is always good repair habit to turn OFF device before repair work. The 3g seems to be less vulnerable to device failure during repair when ON compared to 3GS. If you want to turn your iPhone OFF, you can use program TinyUmbrella to turn it OFF. Open TinyUmbrella connect iPhone to computer, click on the iPhone name, click Enter Recovery button, this will put iPhone into Recovery Mode, unplug iPhone wait 30 seconds it will turn OFF. Only way to Exit Recovery when you are done with the Repair is to use TinyUmbrella, connect iPhone let it turn on, if still in Recovery Mode, click iPhone name, click Exit Recovery button.
из Brad
when your getting to the lock button after opening up the phone is it necessary to disconnect cables 4, 5, 6? why is this? when i opened up the phone it was super dirty it looks like tiny tiny shards of cardboard or something should I clean it? what should i use? thanks to all the responses
из Ryan
