Model Number A1707. Released June 2017, this MacBook Pro features Kaby Lake processors up to the 2.8 GHz quad-core Intel Core i7 processor with Turbo Boost up to 3.8 GHz.
327вопросов Показать все
Can MBP (2017 / touch-bar)'s battery be replaced without losing data?
Can MacBook Pro 2017 (15-inch / with touch-bar)’s battery be replaced without losing data?
I've heard that battery is combined into top-case which includes CPU, memory and SSD.
I have some trouble only with battery, but I wonder is it fixable without losing data?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
In summary, without knowing the symptoms, we will assume that your diagnostic is correct, that the battery is bad, in which case you can replace your battery or top case without losing your data.
The long answer:
The mother board has on it the CPU and storage (SSD). The battery is glued to the top case which is independent from the mother board.
The top case can be replaced entirely, or you can replace just the battery (takes mores skill and time, saves money). Follow this link to learn how, and what tools to use.
This, of course, assuming the battery is really bad since at 2 years of age, they should rarely fail; detailed symptoms can help validate battery failure as sometimes other issues on the board can prevent the battery from charging, and/or the charger itself can be bad.
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
Thank you so much for your answer!!
I just sent it to a repair shop now, and I was told that It's surely the problem about battery but it need to replace "top-case".
This is perfect answer for me because I wondered whether "top-case" is independent or not.
Thanks for helping me out. I really appreciate that!
из
Добавьте свой ответ
nick jonas будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 4
За всё время: 347
