1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
191вопросов Показать все
MacBook Air without battery is having date/time issues
I’ve been running my mid 2011 macbook air without its battery because it swelled up. Today when I started it the date and time are wrong and won’t update automatically even though I’m connected to wifi. It also can’t determine my location. Is this something that replacing the battery could fix, or is it unrelated?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Without a battery volatile data get lost when you unplug the Magsafe, that’s normal and a new battery will surely fix the issue. No idea why time and date wouldn’t update though, double check your settings in system preferences..location services need appropriate privacy permissions.
Был ли этот ответ полезен?
Оценка 3
2 Комментариев:
I’ve checked system preferences and also reset the PRAM, still no luck
из
Your system will learn the date & time from the network time server Apple offers but it will be based on the default time zone, it does take a bit of time for the connection to establish.
You really should fix your system with a new battery.
из
Добавьте свой ответ
Max Richmond будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 160
