Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4969вопросов Показать все
My iPhone screen is dark but work by seeing under a bright light
While I was uploading 3 of the apps at the same time, the screen went black . My phone screen is dark and the only way I can see anything is with a flashlight. Battery life is good. The touch is working. I can answer calls and do everything I normally do on my phone as long as I'm using a flashlight to brighten the screen. Even I can check my emails, can took pictures, can reset everything in the phone by using a strong flash light. The phone is in perfect condition, there's absolutely no physical damage to it and I have never dropped it in water. I have dropped the phone here and there but always with a case on it so there has never been any physical damage. I did the hard reset, factory reset nothing working to get back the bright screen. So far my phone is working normal, only the back light seems to be gone.
Does the LCD screen replacement will solve the problem?
Or
Is it a problem with motherboard so, I may not able to recover normal bright screen of the phone even replacing the LCD screen?
Thanks a lot in advance.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
—-NO
—-YES
Был ли этот ответ полезен?
Оценка 1
1 Comment:
Thanks a lot for being specific.
из
Наиболее полезный ответ
If it's happened out of the blue with no previous damage it would most likely be the backlight circuit, or some part of it. This isn't really a DIY repair, u will need someone who can microsolder and is capable of repairing the backlight for u a good repairer would obviously try a working screen for u first before doing any work to rule out the screen
Оценка 2
2 Comments:
Thank you so much for the details.
из
It's really helpful!
из
Добавьте свой ответ
Nelufa будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 7
За всё время: 594
